propeller shaft special bolts
Going 4.57 & reinforced diff so I need to get my diff out to UPS it to the shop. I've never pulled a Honda diff before & see in the Helm manual that the propeller shaft "special bolts" are indicated "replace" during reassembly. I didn't see any reference to replacing these bolts in xviper's most excellent post on diff removal/gear install & wonder if anyone can give me some additional guidance here. Really necessary to replace them, assuming I can twist em off without damaging them? Or not? Thanks! (I'll need to order them.)
If you get them off without damage they are fine. The problem is that they round out pretty easily.
The trick to removal without damage is to loosen them with a quick hard push on a breaker bar rather than slow pressure. I stuffed two before using the breaker bar and the rest were fine.
As Aus just indicated, I use a quick "snapping" motion to get mine started. They all came out fine and I re-used them. Make sure that the hex wrench is solid in the bolt head, perfectly square before you "snap" it. Although it will make little difference, spray a bit of Liquid Wrench or WD-40 on the bolt head and also where the bolt comes out on the other side and let stand for a few minutes. It might just make all the difference that you need.
Get a high quality 6mm socket. Plane the tip of the allen head on a bench grinder, so the edges are square with a sharp edge. It will give you a lil more bite, works great.
Thanks very much for this great information. My car is low miles & very clean underneath so it's got that going for it. I'll give the bolts a wd40 bath and see what happens. Replacement bolts on hand sounds like a good idea. A tip of my hat to you all!
I think most of the bolts that are spec'd for replacement is due to an expected stretch when torqued, not because of damage. Obviously most of us reuse the bolts but the engineers had something else in mind.
Originally Posted by honda9krpm,Jun 15 2005, 02:12 AM
drain the diff oil as well
a dry s2k diff is around 30kg
However, it is a lot less messy if you drain it while it's still on the car.
