problems with oem drilled/slotted rotors
Recently they are starting to grind and make a grinding feel when im lightly on the brakes. (right front) If I stop hard they dont. Is this normal? Also I slammed them at about 60 and only my left front squeeled before abs kicked on. Does that mean the right front isnt closing properly?
thanks
TJ
thanks
TJ
Were the holes drilled after the rotor was cast or was it cast with the holes?
Any cracks (even hairline) in the rotors? Have you checked what your pads look like? Sometimes drilling/slotting and eat away at your pads in an abnormal fashion.
lol no i bought them that way, they were drilled/slotted before I bought them, from a brake company in VA. im goina check and see if anything is loose later this weekend..
