Problem with water in tail light
Hi
I've a litle problem with water in tail light inside the car. Water is allways after very very pour rain and I can see them when I twist soundly left or right side during the drive. (Beads from the light). My soft top is in perfect condition , no of hole rubbing etc
Any ideas??
Thanks for help
Any ideas??
Thanks for help
Maybe try removing the bulbs and put a hair blow dryer at it. That might warm up the water molecule and cause it to evaporate. I don't know how a spider work its way into my passenger side tail light, but now it dead
I had the same problem with my passenger side taillight. I found that water creeps from under the taillight even from soapy/bubbly water when gentle washing (no direct spraying). No more problem after I put silicone sealant all around.
I drilled a hole from the top to clean the dried water at the bottom (with a wire hanger and pieces of cloth at the end) then sealed the hole when I was done.
