problem on my ap1
problem on my ap1
I had a problem on my ap1 now. got my top down for a run on the expressway and drove by a gas station to fill up (everything was normal till I turn my car off). after filling up my car won't start. I asked some help from a few people to push my car to have it started.luckily my house was just about 3kms away. along the way when I switched on the "bright" front lights of my car the eps signal started to blink. then the eps light retained then next is the abs light. then my radio started to shut off. my defi gauges dimmed and my headlights died as well. each happened on a series one by one. luckily I got home, had my ap1 to sit for a while then tried to start it and it won't. after a while my gauge came back to normal, my radio works fine as well as my defi gauges and my headlights are ok.
I tried to troubleshoot some fuses and I can't find the exact alternator fuses on the cabin and under the hood. I found out that my eld fuse inside the cabin was blown that is fuse no.6 and my fuse no.25 also blew.
now my car still wont start... hoping that replacing those fuse will fix my problem and my ap1 will start tomorrow morning after having my battery recharged. (im from the Philippines so its about 1:30am here right now)
now I want to ask where is the exact alternator fuse on the cabin and under the hood for me to have it checked tomorrow morning?
and what does the eld unit do literally? sorry for my very ignorant question
forgot to mention that my mechanic removed my alternator and returned it back before having that run on the expressway thing that i've mentioned above.
