Problem with motor
Problem with motor
I have a 2000 S2k and when I accelerate sometimes at low rpms it has a sutter like its running out of fuel. I also have a problem when I accelerate hard to about 7rpms and it like hits it limit or something. I changed the spark plugs and the fuel injectors even still the fuel injectors are having low readings. Does anyone know what's going on? Did I blow my motor? Thanks
what air filter are you running? maybe it's dirty?
I haven't done this on my s, but i had this issue on my old civic and it was the fuel filter....those are my first 2 guesses.
If your getting low readings at the injectors (and have new ones) then its most likely a clogged fuel filter. Change it then see if it helps. That would be the first thing I would do.
zeroptzero
01-14-2010 03:40 AM
