Problem with jdm engine swap?
Old 11-27-2007, 12:23 PM
ocd_2k3's Avatar
it started but then 5 sec it turned off. the car runs fine with the usdm ecu but theres no vtec and it cel comes on
Old 11-27-2007, 12:28 PM
gotswap's Avatar
Did you swap out the vtec assembly?
Old 11-27-2007, 12:44 PM
ocd_2k3's Avatar
i just swaped vtec solenoid could that be it
Old 11-27-2007, 12:46 PM
gotswap's Avatar
Are you using the one with one or 2 plugs?
What ECU are you currently running?
Old 11-27-2007, 10:07 PM
ocd_2k3's Avatar
it only has 1 plugs
Old 11-28-2007, 10:45 AM
CrankDatVtec's Avatar
why put the JDM engine, isnt it identical?
Old 11-28-2007, 11:15 AM
gotswap's Avatar
If you are using the jdm ecu use the one plug assembly, if you are using the usdm ecu use the 2 plug assembly
Old 11-28-2007, 11:58 AM
F20_C's Avatar
He is running a USDM ECU.
Old 11-29-2007, 08:26 AM
speedworksracing's Avatar
jdm has more compression and a little more power. However this seems like a major pita. good luck with the swap.
Old 11-29-2007, 02:01 PM
veilside_s2k's Avatar
i jsut did the swap. got mine from hmotors
udsm ecu
usdm solenoid AND usdm engine/wiring harness
no problems.
heres the link to everything
http://www.honda-tech.com/zerothread?id=2109684&page=1
es2thousand
05-29-2014 03:02 PM
S2K_PAT_THOMAS
10-11-2013 10:28 AM
greenthumbs88
11-21-2012 08:08 AM
chikin tities
07-23-2008 07:26 PM
20vmini
02-15-2005 10:04 PM
Quick Reply: Problem with jdm engine swap?
