Problem with Harbor Freight Siphon Pump Kit
I can't seem to siphon anythng with my new pump. I've ensured the the two outlets are tight and being used correctly but it still fails to siphon both differential fluid (Mobil 1 75w90) and water. I've noticed that the pump is not sealed air tight to the container. Could this be the problem? Thanks guys.
http://www.harborfreight.com/cpi/ctaf/disp...Itemnumber=3878
1 Post
I have had and used this pump for years, no problem, I will say though, it does take some work to get it started sometimes....
Pump more, pump harder, don't worry, your palms won't grow hair
Is it normal for there to be such a big gap between the shaft of the pump and the container though? At the moment, my pumps seems rather futile so I'm deciding whether to give warranty a call.
