Primary O2 Sensor - sensor wire
OK lets see hos fast and good you guys are
There are four wires to the primary 02 Sensor on a 2001 S
One black wire
Two Whites
One gray
I am putting in a AF gauge and need to connect to the sensor wire. Which one is it and how certain are you?
One black wire
Two Whites
One gray
The one I stated is for the primary O2 sensor - the one you want for a narrow band a/f gauge. The secondary (sensor for the cat) is located elsewhere.
There are 3 connectors coming out the bottom of the ECU - a 25P, a 31P and a 32P. Find the 31P one and look for the white wire at the pin 16 position (near the central cluster of wires).
I just told you I'm positive. Would you like me to fax you a signed affidavid?
