Preventing Rusted Lug Nuts
I am doing some maintenance on an older car. I had a hard time removing the lug nuts and the wheel was rusted to the hub. What are some tips to minimize rust in these areas?
(I assume this would apply to the S2000 as well).
THANKS!
THANKS!
Originally Posted by thetz99,Apr 24 2005, 09:17 AM
CLR to remove the rust and calcium deposits then Boeshield T-9 which leaves a coating to prevent the rust from returning
Utah
Worldwide Quality Director
Browning/Winchester Firearms
Glad I could make your day Utah. In celebration, I went outside and emptied my 9mm into the sky and then ran back inside before they came back down
I use T-9 on everything on "Shiney" btw
Be careful when putting anti-seize (copper grease), or any lube on wheel studs.
It changes the torque needed to keep the lug nuts tight on the studs.
Nothing worse than loose nuts on your stud.
Regards,
BD
Regards,
BD
I agree w/Coral Doc.. I live in Rochester, NY and put never seize on my lug nuts/studs every Fall when I rotate to my winter tires. I've been doing this for 15 years on Volvo's, and Chevrolets. I don't torque my wheel nuts to a specific torque: I just use a 3/4" breaker bar and get them tight. I haven't had a wheel fall off yet!
The key is to only use a small amount (half fill the nut), so that the excess doesn't "flow" out onto your rotor..
ScienceofSpeed
03-12-2009 05:26 PM
