Pressure gauge problem!
I had installed and oil gauge and a boost gauge on my AP1 and they look great @ night. However, I wasn't able to located a good location around the intake to installed the pressure line. I wanted to cut a some hoses and try my luck but I decided to get back into the forum and see if anyone has installed one of this before and if possible obtain picks of previous installments on where to obtain a nice pressure point on the intake. Thanks for the help everyone and if anyone have questions on how I installed my gauges I will be glad to help just ask.
the boost gauge runs off the vaccum in the manifold, just look under the hood and you will see it.
not sure i read you right but you are running boost gauge on a NA car?
even if you have a boosted car, you don't run the boost gauge to the intake/compressor inlet pipe.
btw where did you tap the oil pressure from? if you are using those cheap brass tee's off the oil sensor, you might want to buy a proper fitting. those brasss tee are known for splitting the port
SpeedxRacer
Member S2000 Classifieds and For Sale
09-10-2009 08:07 AM
