Preloading Suspension
Old 06-27-2008, 10:04 AM
  #31
nearwater4me's Avatar
Yeah, looks like the ABS sensor wires were damaged.
Don't get too intimidated though.
Everyone makes mistakes.
What's important is learning from those mistakes.
Good luck!
Dan
Old 06-27-2008, 10:08 AM
  #32
Originally Posted by frofro24,Jun 26 2008, 11:42 PM
You don't need to take off the rear A arm, either way I believe the spec is 75.9 ft lb, and the spec for the LCA is 47. it is always good to use a little anti-seiz when putting everything back together. Make sure you get a alignment too.
I am not responsible with the outcome if you use theses specs.
I've read two threads about the preloading in the sticky thread, and one states that the front upper A-arm should be torqued to 75.9ft-lb, but the other thread stated 97ft-lb for the rear a-arm.
I guess it's different.
The reason I wanted to re-torque the rear upper A-arm was because of the changed ride height.
Stock settings should be set to stock ride height, not lowered ride height.
So I figured it might be a good idea to loosen the bolts and retorque to the lowered ride height.
Anyway, I retorqued everything last night and looks good so far.
Dan
  #33
mindphunk's Avatar
Ok, so hopefully all I've done is pulled the wire somewhere. I'll have someone look at it on Monday. Thanks for your help.
Old 06-27-2008, 10:16 AM
  #34
Not a problem. Glad we could help
Try to follow the ABS wires and see where it's disconnected before going to the shop though.
You might be able to solder it back on if it's not cut from the connector side.
Dan
Old 06-29-2008, 02:03 AM
  #35
SDSILVERM3's Avatar
After doing the install on my car yesterday I can definitely see how it could happen. You don't get much slack with that wire especially with the a-arm unbolted and would need someone to hold the rotor and caliper if you were to step away otherwise stretching is likely.
Hope you get this resolved.
Old 07-01-2008, 06:02 PM
  #36
mindphunk's Avatar
I took it to a performance shop today and had them order the part. $100 installed. Car looks great though and they checked my install and said that everything was fine.
Old 06-07-2009, 10:14 AM
  #37
Picturepro's Avatar
Bump...
sorry to bump a old thread but I questioning the Tq specs
I've read both control arm Tq specs
79 and 97 were there some dyslexic post??
I replaced my 2005 with 79000 miles one leaking for 2008 with only 400 miles. Shock and springs complete O.E. I had a knock over speed bumps so I pulled it apart put some grease on the contact points at the control arm, body and a little on the bolt shaft due to some corrosion and rust
Hope 97lb is ok
re-torqued the shock mount on lower control arm to 47lbs as listed in a couple post
Can someone please confirm the correct specs PLZ
Old 06-07-2009, 01:26 PM
  #38
CKit's Avatar
Rear Lower arm to body, the long single bolt without a nut: 90.4 ft*lbs
Rear Upper arm (each of the two long bolts): 97.6 ft*lbs
That's what my shop manual says, anyway.
Old 06-07-2009, 03:44 PM
  #39
Picturepro's Avatar
Front: Driver and passenger at 97lbs, two long bolts each side.
Shock mount on lower control arm 47lbs
cool Thank you
This would be useful information to ADD to the post on Tq. specs
Old 08-24-2014, 06:23 PM
  #40
Slowcrash_101's Avatar
Sorry to revive this thread, but if you install a new shock/spring combo, do you have to loosen all the suspension bolts that have bushings(ie the bolts holding the upper and lower control arms), jack up the suspension then re-torque them after jacking up the suspension or only the ones you loosened to install the shock/spring?
I recently installed new shocks/springs, unbolted the upper A arm bolts(on the fronts, didn't touch the rears), then hand threaded the UCA bolts in, then jacked up the control arm until it lifted off the jack stand, then I tightened the shock assembly and control arm bolts. I'll be doing an alignment soon, but I'm worried if I did it wrong as I have a three finger gap in the front. I also didn't lift at the brake rotor but on the actual control arm itself(just inboard of the ball joint castle nut). I haven't gotten the car aligned yet as I'm letting her rest a few days to let the suspension settle, the car handles fine from what I can tell. Again, I'm worried I did it wrong and that I am going to chew up my control arm bushings. I'm also going from lowered, to OEM height as I don't really care about having a lowered car anymore.
Quick Reply: Preloading Suspension
