power window auto problem
Originally Posted by tekstar,Jun 2 2009, 12:00 PM
to haikus lol
the faulty window regulators were only issues with some ap1s. the op should be able to reset it using the procedure described
My passenger side window now won't go up or down. You can heart the click when you hit up or down, but nothing happens. Now it's in the down position, and I don't like parking anywhere since I can't put it up now.
Otherwise, each window has its own fuse...try that?
Tried that, with the disable switch in the "on" position, you hear the click of relay on the pass side, but nothing happens. When you turn the switch off, no click. Checked all fuses, all good.
I know the door panel was off as I just jad some paintwork done, and I think they probably removed the door panel to take the mirror off before they painted. The window worked 2-3 times after I got it back. I'm just not sure I want to drive it 30 mine all the way back to have them mess with it. I'd like to try myself, but not sure what to look for?
download the helms manual and find the trouble shooter, pull the panel on the passenger side and follow the trouble shooter. It will isolate your problem for you by allowing you to check every circuit.
When mine did that, it was the module behind the panel, took about 10 minutes to identify it.
fltsfshr
fltsfshr
