Power steering fault?
I am sorting a few issues resulting from a small engine fire caused by loose oil filter.
My main issue now seems to be with the power steering system.
The EPS light is on. And makes a rumbling sound when turning left, only when turning left.
I have checked the electrical connecters, they are a little gunked up, but not too bad, and wiring not melted.
Anyone any ideas what this could be?
Cheers
Cheers
It was not a massive fire.
This is what the rack looked like prior to clean up.
If it's making the rumbling sound, does it sound like I will need to replace the whole rack?
Also could damage of occurred from being towed a short distance with no ignition?
EPS is electrical. So I supppse low voltage could cause issues. Not sure of the issues you are having, but I would first resolve the batt issues before troubleshooting EPS further.
Thanks, I charged the battery, and it made no difference apart from the engine starting quicker.
I decided to remove the whole steering rack. There is nothing obvious, the plastic around the torque sensor is a bit brittle?
It does also make a very slight grind sound pushing it side to side.
So I've ordered a second hand rack, as well as control unit, new track rod ends and new anti-roll bar links.
So I am hoping with that lot replaced it should sort the issue?
WashabiS2K
11-06-2007 10:59 AM
hyperpm
09-17-2003 01:58 PM
