power outlet ng?
power outlet ng?
My portable air compressor works fine when plugged into my Jaguar's power outlet, but won't work off the one in the S2K. Has anyone else had a similar problem?
I saw a power outlet mentioned in the fuse box. Assume this is not the cigar-lighter type, right? (Yes, I know I could go out and crawl under but hey, I'm lazy.)
I run my el-cheapo air compressor off the center plug all the time. It is a switched plug (turn ignition key to on). I idle my car since I'm paranoid about my battery. I noticed the fit is tight with most of plugs, maybe you're not fully inserted (no XXX wisecracks guys!)?
My power plug has been loose for a while. I also use a portable compressor, but have to switch when using USB adaptor for GPS. It finally came loose after all the changes. Looks like threads at the back end and a metal sleeve the wires run through.
Any suggestions on resnugging it before I start disassembling?
