power and mpg drop
It's my understanding that Ethanol is a lower energy fuel, so yes, you would see a performance decrease as the amount of Ethanol increases. There have been tests where the actual Ethanol content has exceeded 15% at certain stations. This should be the only time you experience a noticeable decrease in power from our cars, since Honda says Ethanol is an acceptable fuel.
Couple of things to check/do.
New air filter
Clean throttle plate (will do a lot for your idle if dirty)
check spark plugs condition and gap
check PCV
check tire air pressures
get a fresh tank of gas and reset ECU
I use shell almost everytime, different stations because I travel a lot (173K). I have gotten some tanks that have yeild some bad MPGs (rare) but mostly they are good.
I find that if I'm on a tank of gas and the weather conditions change a lot then the mileage isn't as good as using a tank in one or two days in while the weather variables are more constant. My guess is the ECU adjust based on gas quaility and sensor inputs.
New air filter
check PCV
Hi. I unplugged my ECU, and now i got my 4-5krpm power back. Haven't tested the Mpgs yet, but I'm sure it will go back to normal. Probablty a bad batch of gas caused all this. Thanks for all your help.
