Power Loss after Hitting the Rev Limit?
Old 09-08-2018, 10:38 AM
Car Analogy's Avatar
Received 1,438 Likes on 1,071 Posts
So wait, I thought everything was bigger in Texas?
Old 09-08-2018, 01:46 PM
noodels's Avatar
Need to wait for correct learn from EMS after a reset,
have you given enough time and done correctly ?
Old 09-09-2018, 02:36 PM
jts09's Avatar
Yes, everything is bigger in Texas, except hills (in North Texas at least).
I unplugged the "Back Up" fuse for several minutes to reset the ECU, but it isn't obvious if the ECU was actually reset? I didn't notice any change in idle or performance. I've put a few hundred miles on it since.
It's been a pretty hot summer. Could I be experiencing "Heat Soak"? I've seen some posts about it, but not many specific details of the conditions that lead to it?
Old 09-09-2018, 02:53 PM
Conditions? Its hot. Engine is hot. Intake air is hot.
Cold air is dense. Power packed. More air, more fuel, more power. Crisp throttle response.
Hot air is the opposite of that.
Old 09-10-2018, 05:32 AM
jts09's Avatar
OK. Guess I should have been more specific. Is there an ambient temperature threshold for Heat Soak effects on an S to be noticeable under normal driving (non-track)?
jts09
03-18-2018 09:29 AM
LBPS2K06
05-31-2017 08:32 AM
Nickleby4
04-23-2013 09:01 AM
OVER 9000!
12-02-2011 06:18 PM
rocketman
03-30-2001 11:18 PM
Quick Reply: Power Loss after Hitting the Rev Limit?
