possible to turn off the car while driving?
Originally Posted by Haulin' S,Mar 16 2006, 12:46 AM
Car comes to one heck of a jerky stop and ticks off whoever's behind you!
The steering wheel will not lock unless you turn the key to the "off" positition and then remove the key from the ignition switch. If you turned the keyy to the "off" position, with the car in gear and the clutch out, the motor will spin until the clutch gets pressed in or taken out of gear.
The reason the start button was not needed, was because the car was going 80-85 mph "in gear", meaning the engine was spinning the whole time.
Originally Posted by Incubus,Mar 16 2006, 03:20 PM
I've been in a Civic where the driver took the key out of the ignition to unlock the glove box. I guess we got lucky.
Originally Posted by RACER,Mar 17 2006, 02:27 AM
The steering wheel will not lock unless you remove the key from the ignition switch.
Originally Posted by Ed_Grant,Mar 17 2006, 10:33 AM
==yes it will. the key can be in the ignition, and the steering wheel will lock if the key is in the "off" position.==
I agree (just tried it).
If you just stick the key in the cylinder without turning the key to the "ON" position, of course it will be locked
