possible to do oil change?
#23
Hummmm, I ride my S up on a 2x6x10" board, slip the waste oil container under the car; loosen the oil drain bolt (from the top); drain oil; reposition the waste oil container; loosen and remove the oil filter (from the top); refit a new filter (from the top); reinstall the drain bolt (from the top); remove the waste oil pan; give the drain bolt an extra tug with the wrench from underneath (using box end wrench); fill with oil; and drive away ..... done .... no jacking, jack stands needed.
Don't make oil changing harder than it has to be .....
marlonRocks
10-02-2007 07:45 AM
