Is it possible to do a clutch job without lowering subframe?
Old 10-06-2016, 10:15 AM
freq's Avatar
Depending on how a car is dragged onto and strapped down to a rollback or trailer, yes, the alignment can get jacked up.
You don't really think EVERY tow truck driver is gonna look for and install that OEM tow hook do you? They'll throw that hook on anything solid to get that car on their equipment as quickly as possible. Damage be damned.
I'm not saying that's what happened but ti does happen.
Old 10-10-2016, 08:24 AM
solitarycheese's Avatar
For the record, I was present when the car got put on a flat bed. I screwed in the OEM tow bolt, and helped steer the car onto the flatbed (car was in my garage at the end of a 50ft driveway). If I recall correctly, the driver secured it to the flatbed with straps around the wheels.
Old 10-10-2016, 03:19 PM
freq's Avatar
Good info and smart move.
So we know that wasn't the reason for the misalignment.
Old 10-11-2016, 03:19 PM
So I followed this procedure to check if its a steering wheel alignment issue, or a regular alignment issue. I think it's pretty clear the mark are canted, meaning its a steering wheel issue, right?
Drive the car as straight as possible on a flat level surface (driveway or parking lot). Hold the wheel perfectly still and stop the car with the wheel in the "straight ahead" position. Put some tape at exactly 12 o'clock on the steering wheel and then turn it to the stops in the left and right directions. At each stop, put another piece of tape at exactly 12 o'clock. After you've marked both limits return the wheel to the straight ahead position (first tape at 12 o'clock). Both your "limit tapes" should be at equal distances (angles) from the "straight ahead" tape. If they're not the alignment is wrong. If they match, the steering wheel is postioned incorrectly.
Old 10-11-2016, 03:21 PM
Sorry, bad link (didn't see an option to edit previous post). https://drive.google.com/file/d/0Bye...NyQ1pyWXc/view
solitarycheese
10-13-2016 12:30 PM
humbucker87
05-01-2013 08:40 AM
Hyper-X
11-09-2004 06:28 AM
Mrcln1
09-21-2004 06:09 PM
beaudot
04-26-2002 03:24 AM
Quick Reply: Is it possible to do a clutch job without lowering subframe?
