Possible Clutch Problem...Help Please!
Old 11-30-2012, 06:56 AM
BenS2579's Avatar
Awesome replies! Thanks guys! When I don't throw it into gear quickly it does seem to shift better. Also, the clutch fluid is dark, so I'm going to replace that and all the other fluids as well. But since it's bad to skip gears, what do you all think is wrong with my 5th gear? It's like pushing on a brick wall now. And if it does go in, it's with a lot of force, and only goes half way in until I let the clutch out and it pops out of gear...I'm hoping it's not a synchro, but I'm (obviously) not good with diagnosing transmission problems.
Old 11-30-2012, 06:50 PM
ronnuke's Avatar
Some have had some good results by having the engine off and shifting between 5th and 6th gears repeatedly to remove burrs that may be causing the "hard to get into 5th gear" problem. HTH
Old 11-30-2012, 07:02 PM
BenS2579's Avatar
I read that on here but i only tried it once and it didn't seem to get any better. I guess ill try it a lot more lol
Old 12-03-2012, 07:36 AM
4forall's Avatar
One thing that has not been mentioned, (all above are great input, check those things out too!), but the small plastic cup at the bottom of the shifter that goes into the transmission may be broken and not allowing you full range of motion of the shifter. Try the dry shifting into 5th and 6th repeatedly as well as all of the above suggestions and report back.
Old 12-10-2012, 03:55 PM
BenS2579's Avatar
Thanks for the reply!^^ But no, it won't even go into 5th with the engine off and the clutch in. I took a video of it just a while ago to show you all. No matter how much pressure I apply to the shifter, it still won't go in. Not even half way now.
Btw, in the video, my seat is what's squeaking and what-not, not the shifter lol
Link:
Video
Old 12-11-2012, 01:28 PM
BenS2579's Avatar
Bump! Any ideas?
Old 12-11-2012, 04:29 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Search for threads regarding "lost 5th gear after track day". I have posted a quick fix method. Your 6th gear collar is burred up, causing your 5th gear issues.
Old 12-11-2012, 06:25 PM
BenS2579's Avatar
I read a few posts about putting it in 5th and 6th then once getting it in, going down the road and getting up to 6k in 5th and flooring it and letting off....but i just cant even get it in 5th :/
xXx butane xXx
01-12-2007 04:08 AM
S2KFinest
04-24-2006 01:18 PM
nookie4everyone
06-07-2003 10:01 PM
Rick Hesel
02-17-2002 12:20 PM
pnty drpr
05-22-2001 03:21 AM
Quick Reply: Possible Clutch Problem...Help Please!
