is it possible to activate "peak power indicator" on my 08's?
hey guys!
As you know, '08 CR has "peak power indicator" on instrument panel.
And I have '08 s2000 not CR model,
but both '08 CR and '08 S2000 has almost same instrument panel.
And I found a "peak power indicator" light is located on my s2000 same place as CR's.
I think if some parts added, I can use that light like CR.
Is there anyone did this??
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
you have a coolant temperature guage for that, at 3 bars you have maximum power, that's all the CR guage uses to decide when to illuminate the indicator. You might need a cr ecu if you want to have it working, hopefully the wiring behind the cluster is the same. Definitely not worth the trouble IMO.
