possible ABS (anti lock brake system) issue AP1
Old 02-12-2013, 11:11 PM
b0r1cha's Avatar
so i pulled the ABS fuse and the vibration stopped so i think its safe it say its my ABS giving issues. is there anyway to reset the ABS to try to fix the problem or any other solutions??
if theres any mechanics out there that can help out a fellow s2ki brother, dont be shy i will reward with food and drinks!
Old 02-13-2013, 08:52 AM
Wolf95's Avatar
I drove around all winter without my abs fuse, the 30 Amp one, and I had no problems. I even had to initiate some hard stops from other retarded drivers with no lock up. If you find a cure I would love to know. I've checked everything like you, pads, rotors, cleaned each sensor, replaced a caliper, and bled the system..... Still acted up. I got annoyed and pulled the fuse. So I'm also waiting for the time/money to have a pro check her out and see what the heck is going on!!
Old 02-13-2013, 04:23 PM
b0r1cha's Avatar
yeah im gonna take it to the shop tmrw and have them take a look at the sensors again. hopefully one of us can find the solution sooon!
Old 02-15-2013, 08:35 AM
Wolf95's Avatar
Good luck!!
Old 03-03-2013, 03:37 PM
Wolf95's Avatar
any updates?
Old 04-14-2013, 11:04 AM
xAgyex's Avatar
Update?
Old 04-26-2013, 06:07 AM
Wolf95's Avatar
I'm not the OP but I'm having an identical problem. I put my abs fuse back in after replacing 2 calipers and it's still making that weird "grind" between 5-8 mph. With the window down I also noticed a "pshh" sound from the driver's side under the hood at the same time it does the "grind". At hard breaking, ABS still pulses as normal. I'm having a friend ship me an ABS module today that I'm going to try and see if maybe a piston in the ABS unit is frozen or stuck. I'll update with results.
Old 07-29-2013, 11:43 AM
cmn
cmn's Avatar
Any updates? I'm having the same problem... Also, if I go faster than 100-110mph, the ABS light turns on and the ABS is disabled.
trackrabbit21
08-11-2015 11:14 AM
Memo6453
06-04-2015 08:12 PM
Blindeye_03
08-08-2012 06:51 AM
CoralDoc
08-12-2010 04:47 PM
Quick Reply: possible ABS (anti lock brake system) issue AP1
