Poor brake performance and feel. Need to bleed BMC?
ok cool. Yeah I just read that using some clamps seem to work better than the chain and j hooks. I also read that the stock cap won't seal well enough to handle the pressure inside.
I think I will give this a shot. Can't hurt at least and should help get any air out of the BMC if there is any in there. I may just buy a new one to be safe though.
Seems they are sold without the reservoir. Is anything else needed like seals or gaskets to install my reservoir onto a new BMC?
You only need about 7-10 psi to bleed the system. I need to go dig up that post where someone used the oem cap. He may have modified it in some way to get a better seal.
If it's the modulator, an ABS event could cycle the valves and fix the problem. Sometimes on older cars contamination can get into the outlet valve seat, which allows fluid to fill the secondary circuit that is closed under normal braking. When you pump the pedal, it fills the secondary circuit and once the circuit is filled it will build pressure and feel normal. Try an ABS stop or 5 to cycle everything and see if that helps. This condition doesn't cause an ABS code either.
Sounds like a bad booster to me, do you see the paint on the booster flaking off? That would tell you that you have a ripped diaphragm, or the seal to the booster is bad. Remove the vacuum line and see if braking effort is the same.
Former Sponsor
I'm thinking there is air trapped in master cylinder or something.
I will buy a new master cylinder since I have such high miles anyways and see how that goes. I bought the power bleeder so ill use that as well to force any air out of system.
Any seals needed to be purchased when swapping my stock brake fluid reservoir over to new master cylinder?
New master cylinder with new lines, calipers, pads, rotors and fluid better fix my braking issue lol.
Originally Posted by Moddiction
Prefer not to buy used as you never know condition of the used part.
Centric is a crappy Chinese company. So while it may look the same the castings could be weak, a c clip could fail, something super innocuous.
Just look for a low mileage s2k in a wreck and buy a master cylinder. Better than buying some Chinese pos and have it explode and losing all brake pressure.
If a Chinese rotor cracks you will still be able to brake bc there are 3 other healthy rotors. If the master cylinder fails you better hope you have lots of runway to bleed off speed.
Google the failures of knock off brembo radial master cylinders (on motorcycles) - the castings are shit and they will crack or the c clip under tension will fail. The rubber nipple will fly off. Etc
