PLX M300 Wide Band and AEM EMS
Old 05-12-2005, 03:37 AM
S2000_Europe's Avatar
Thumbs up PLX M300 Wide Band and AEM EMS
I have seen their web page but which A/F sensor do I have to connect the white cable (0-5V) the #1 or #2?
Thx
Old 05-12-2005, 03:40 AM
beroznikmal's Avatar
Not sure it matters which one you select #1 and #2 should be the same....
Old 05-12-2005, 02:58 PM
AusS2000's Avatar
IIRC I replaced the O2 #1 sensor and just tapped into it's line up at the ECU extension.
Old 05-13-2005, 12:26 AM
IIRC???
the O2 #1 is where the wideband are before the cat
the O2 #2 is sensor after the cat.
From this intruccions I understand:
http://www.plxdevices.com/PLXApp003.htm
Connect the wideband cable (0-5V) where the O2 #1 AEM 's pin. and then set a range value, in this case 5V right?
I don't really understand very well the graph.
Beroz Can you take paic of your connection? I think you have the M300 and AEM EMS
Regards
Juan
Old 05-13-2005, 12:59 AM
AusS2000's Avatar
IIRC???
If I Remember Correctly
[QUOTE]Connect the wideband cable (0-5V)
Old 05-13-2005, 02:01 AM
Thanks!!! Wayne.
Old 05-13-2005, 04:36 AM
Juan,
I could but my car is in the shop for some MINOR upgrades....
Do yo have the situation under control?
Old 05-13-2005, 04:57 AM
I think so, This Sunday Will do the connection to have evrything done when SEan comes here on Wednesday
Juan
Old 05-16-2005, 08:27 AM
So according to the instructions I cut the cable that goes into the pin C16 (sensor #1) which was connected to narrow band cable of the sensor. Then i tap it with the wideband cable of the sensor, so the AEM is going to read a range of 0-5V intead 0-1V. This connection seems logical for me
Sensor #1 Wideband 0-5V (Wideband sensor)
Sensor #2 Narrowband 0-1V (Stock sensor)
Is this how you have do it?
Old 05-16-2005, 02:48 PM
AusS2000's Avatar
There is no reason to cut the wire. Mine still goes under the car and terminates on top of the gearbox. The connector is wrapped in electrical tape.
The AEM signal just taps into the wire on the P'n'P harness.
Quick Reply: PLX M300 Wide Band and AEM EMS
