PLEASE HELP me verify my vacuum lines!
i think the shop that installed my clutch may have forgotten to put back a vacuum hose. i got a P0411, and after reviewing the AEM installation guide, i realized that the "lower vacuum hose" was missing. i put one back on, but i'm not completely sure if it's correct.
i've circled the area i'm not sure about.
also, when i took my car back to the shop after i got the CEL, they put this T-line in. i just realized this, and i don't know if this is necessary. it didn't fix the CEL, because it came on again.
should i take this T out?
You should remove that "T" that your shop installed. Verify that the "upper" vacuum hose goes to the manifold and that the "lower" one goes to the secondary air valve. Also, make sure the vacumm lines at the bypass control valve (3rd pic) are not reversed. I hope this helps.
The following 2 users liked this post by fatjoe10:
NebraskaS2k (06-20-2017),
WilloW (07-20-2020)
wow, ok, billman & fatjoe thanks a lot! the pictures definitely help. i thought the T was BS, and the lower vacuum hose was missing. i'll go ahead and take T out then. thanks again guys!
Mine is not correct either and my car won’t go pass 6,000rpm it’s like it it looses full/hits a brick wall. Did you have similar issues?
