Please Help
Wow i was puttin this off for so long but sounds more and more like the HTG package is the way to go, any issues with engine stall at first with the lightfly wheel, i think i heard a preson or 2 say soemthing about the balance being off slightly from it but not sure what that means
So Billman,
You have used the stock disc ACT PP combo on 500+ whp cars? I have a Spec stage 2 with HORRIBLE rattle and am thinking about swapping back in my stock disc. I know it's a different PP, but it should be similar. Thanks.
Tim
Tim
Bill
You know, it is funny. There seams to be some bad info out there, but I read all of the UTH threads and I think you do as well. So my question is where did this BS get posted in the first place?
Originally Posted by JayStyles662,Nov 23 2006, 01:51 PM
Wow I was told they were better than ACT.
heh not gonna give names cause im kinda buds with the guy but some of the sellers told me this or one of em, but im totally clueless with most of these things so ill usually atleast question what i hear. and the deal with the fly wheel i read on a thread or 2, i can try to find it and post so the truth can be clarified about it
Im curious though, are there any drawbacks to the CT flywheel over the stock flywheel or is that a win/win deal? I looked on HTG's site and could not find the combo package bill was talkin about, does HTG still sell the combo or maybe someone got a link?
there's a group buy right now:
https://www.s2ki.com/forums/index.php?showtopic=438492
i don't need a new clutch yet that badly, but what would happen if i did that package but stuck with the stock flywheel? either original or new OEM (i have 60k miles now). is that a wear item that needs to be replaced? i'm not really sure how all that stuff works.
I replaced my clutch at 35k. Yes I launch the car HARD and bought the car used with 13k so who knows. I installed the Act PP, OEM disc, new throw out and pilot bearings and had my OEM flywheel resurfaced (cut). The Act PP is MUCH better grip is very quick and tight. The lightened flywheels will allow you to Spin up faster. In my opinion this engine revs fast enough and I like the inertia the weight of the OEM flywheel provides. The weight savings IMO was not worth the cost. I have been very happy with this setup. If you have this done be sure they Clean and lube the spline very well, also while the shifter is out disassemble it clean it and lube it. If you have a 03 or beyond eliminate the slave cly delay.
