platinum 4 spark plugs
Old 12-13-2002, 07:14 PM
dmeronuk's Avatar
Default platinum 4 spark plugs
Is anyone using platinum 4 spark plugs by Bosch, and would you recommend yea or nay? thanks Dave
Old 12-13-2002, 08:36 PM
xviper's Avatar
[QUOTE]Originally posted by dmeronuk
[B]Is anyone using platinum 4 spark plugs by Bosch, and would you recommend yea or nay?
Old 12-13-2002, 09:06 PM
dmeronuk's Avatar
Strangely enough I found a listing for a +4 on the Bosch site that is manufactured for a 2000 Honda S2000. It's part # 4417. They don't seem to be available at Canadian Tire yet, but are supposedly available at Schucks in Seattle. I'll find out for sure on the weekend.
Old 12-14-2002, 05:50 AM
xviper's Avatar
[B]Strangely enough I found a listing for a +4 on the Bosch site that is manufactured for a 2000 Honda S2000.
Old 12-14-2002, 12:06 PM
DouglaS2000's Avatar
Don't do it! I've had the Bosch platinum +4 on my 00 Civic Si and 90 Accord and they caused bogging off the line in both cars. I even had a standard Bosch platinum plug on some other cars and everytime, it would cause bogging. Soon as I swapped them out for the OEM plugs, no bogging.
The 2k Civic Si B16a is sorta like the F20c with the high redline (8k, 1k short of our motors) and VTEC changeover at 5-6k rpms, so I would expect that the plugs would cause similar behavior to my Si with the bogging.
Old 12-14-2002, 12:32 PM
Former Sponsor
Gernby's Avatar
I really don't think there is power to be gained just by changing spark plugs, unless it is because of a "better" heat range. I went with the Denso Iridium IK24 (1 step colder than OEM) in my basically stock motor, and they are great. I think it helps prevent the loss of power when it is hot outside.
I think that Honda picked a spark plug with a relatively hot heat range, so that the plugs wouldn't foul out during very short drives to / from the corner market. If you live in a hot climate, and drive far enough each trip to fully heat the plug, the colder plug is better.
I haven't had any good experiences with Bosch plugs either. I think the main benefit of the platinum tip is longevity, not performance. I have always believed that copper plugs provided better performance than platinum, but had to be changed more often. The Iridium plugs, from what I hear, is actually the best of both: long life AND good performance.
Old 12-16-2002, 12:22 PM
S2WOOOW's Avatar
I was also thinking of switching, but I did a search (from MSN home page, not this forum search) and found some very negative reviews. Actually they were all negative. I think most were from Miata and either Porsche or Audi forums. Very similar problems that DouglaS2000 stated.
Old 12-16-2002, 01:29 PM
Pixsurguy's Avatar
[QUOTE]Originally posted by gernby
[B]
Old 12-16-2002, 01:35 PM
xviper's Avatar
[QUOTE]Originally posted by Pixsurguy
[B]
I just had the sparkplug TSB done on my S and they put in Denso Iridiums.
Old 12-16-2002, 02:04 PM
Pixsurguy's Avatar
[QUOTE]Originally posted by xviper
[B]
Lucky dog!
Quick Reply: platinum 4 spark plugs
