Plastic Burnt on Exhaust and Partially melted to helmholtz pipe
Old 10-18-2014, 09:19 PM
uhohitzluke's Avatar
Default Plastic Burnt on Exhaust and Partially melted to helmholtz pipe
Long story short, I somehow got an arizona green tea plastic wrapped up on my GReddy SE
I've tried using oven cleaner and a wire brush to get off the burnt parts on the pipe. I had very little luck. I also don't know how to deal with the semi melted plastic on the helmholtz pipe! That thing is CAKED on there. Any suggestions?
Old 10-19-2014, 12:18 AM
alSpeed2k's Avatar
It will eventually burn off.
Old 10-19-2014, 04:43 AM
Vanishing Point's Avatar
To remove it you will have to have the exhaust fairly hot. I would remove that section. remove what you can while it's cold. Then heat it up and try to remove it while soft with a pair of expendable heat resistant gloves. Once pliable it will rub off onto the gloves, the residue will burn off. To heat it up buy/borrow a small propane tank torch.
Old 10-19-2014, 04:58 AM
Billman250's Avatar
Received 1,395 Likes on 836 Posts
It will not burn off, guaranteed.
I use a 2" resurfacing disc takes it right off.
Old 10-19-2014, 05:20 PM
alSpeed2k's Avatar
^At least the smell will go away.
Motorcyclists apparently like to use Easy-Off oven cleaner. http://www.youtube.com/watch?v=JiKvHZjPxgY
Old 10-19-2014, 05:22 PM
I tried using easy-off, and it did not come off like it did in the video!
Old 10-19-2014, 09:00 PM
alSpeed2k's Avatar
I guess you'll need to try Billman's resurfacing disk method.
Old 10-19-2014, 11:54 PM
stupkid's Avatar
I had the same thing happen to my header on my bike. My dad has a warehouse of chemicals so i grabbed a bottle of acetone, poured it onto a paper towel and wrapped it around the plastic covered spot. Poured some more on then waited a couple of minutes. Then I scraped it off with a razor blade.
Old 10-20-2014, 05:49 AM
Car Analogy's Avatar
Received 1,438 Likes on 1,071 Posts
You can buy acetone at Home Depot. Wear gloves and try not to breathe in too much of the fumes.
I think acetone (or even brake cleaner) would get a lot of it off, without having to remove exhaust. Whatever is left, abrade off using Billman suggestion.
Old 10-20-2014, 12:18 PM
Chris_Lum's Avatar
a razor blade will do the trick, I had to do it with mine..
Quick Reply: Plastic Burnt on Exhaust and Partially melted to helmholtz pipe
