Plastic bits in side drain, don't know what they are
Old 04-02-2017 | 10:57 PM
omgitsoop's Avatar
Default Plastic bits in side drain, don't know what they are
Cleaned out all the gunk in my clogged up soft top drain buckets, and found one of these in each of them. Any ideas what they could be from? Hoping they're not important
Old 04-03-2017 | 12:07 AM
windhund116's Avatar
Parts of a wiper blade?
Old 04-03-2017 | 05:12 AM
Slowcrash_101's Avatar
Weather stripping near the rain drains, it goes under the black plastic frame that the top is tucked under.
Old 04-03-2017 | 06:13 AM
omgitsoop's Avatar
Is this something that can only be reached if the top is off? Or can I get to it via the tray area? (My tray is currently out already)
Old 04-03-2017 | 11:24 AM
jyeung528's Avatar
those are very important rubber pieces.
Old 04-03-2017 | 06:59 PM
darcyw's Avatar
easy to replace without having to remove anything. Put the top down in order to access the space. I was missing one completely and used a piece of rubber windshield wiper. I reinstalled with 3M double sided automotive tape. I believe it helps direct run off water into the drains.
​​​​​​​darcy
Old 04-04-2017 | 10:59 AM
omgitsoop's Avatar
Could I possibly get a picture of someone pointing out where it's supposed to go? I'm a visual learner
Old 04-05-2017 | 12:27 PM
Will do once I get off work.
Old 04-05-2017 | 05:25 PM
here you go good sir. It's near the little brushy part.
S2005x
08-24-2016 05:53 AM
B0neSt0ck
07-02-2012 12:42 AM
MurderS2K
10-05-2010 10:47 PM
EOE
07-18-2009 08:25 PM
the dumontster
08-10-2005 06:37 AM
