Plan for devleopment of high-performance, high-strength differential
#71
OK so not to put a damper on this because I think it is a great idea for FI, etc.... but if the MY04 is 40% stronger than the MY03, how much does it cost to buy an 04 diff and put it on an 00-03? If it's close to $500 you're not providing alot of value. However if you were to take an 04 diff and strengthen it then you may be able to get the 75%-80% stronger which would be valuable.
#72
OEM = expensive.
I think it was mentioned that the 04's diff has a lot of the same work done to it as the comptechs upgrade. So you cant improve it to 75-80% like you're thinking. There's only so much you can improve with one design.
Plus $500 for a whole new diff housing is a pretty good price.
#76
I am definetly in. Mine is humming, I have 410hp at the wheels but I have to turn the boost down because it is too much tourque. The last quote I got to improve my rear end was too back-half the rear entire car, for a sum of $7,000.00. What?, are you kidding? $500.00! put me down for 2.
#78
I wonder if any of the internals from the supposed stonger 04 diff would fit the 00-03 diff?!? sort of like getting an OEM comptech upgrade!!, I dont mean replace the full diff but just upgrade the weakest parts.
Rick let us know how hardtop guy gets on with the 4.57 install.
Andy
Andy
#79
I spoke to Hardtopguy about this a few weeks ago.
The 04 diff carrier assembly (the interior part that actually holds the diff gears and such, is indeed a different part number than pre 04. It's about $350-$400 IIRC, problem is, nobody has yet investigated whether it is stronger than the pre 04 or just different.
#80
Reverend just installed an 04 housing in his car. The jury is still out weather or not it is stronger than the 00-03. After seeing the pics on his website, any differences are difficult to see from the previous model.
