Are Piston Skirt Markings in Cylinders Normal ?
While working under the engine this weekend for the oil jet bolt matter I tried to take a peek up into the cylinders. People suggested looking up at the cylinders while doing the oil jet swap. To be honest I thought it was near impossible to tell anything of what was happening in the cylinders. People talk about the cylinders looking shiny and all, but they have a light coat of oil on them so they naturally look shiny. My engine is a 2002 ap1, 60k miles on it.
Just wondering if it is normal to see markings on two sides of the cylinders where the piston skirts run up along ?. I know the pistons wear more on the two sides with the skirts. They didn't look like deep scratches or anything, but you could identify sides where the piston skirts are. I think in an open cylinder you could feel the walls with your fingers to see how bad they are, but looking up from underneath it doesn't look like much. I just want to make sure that the markings don't necessarily mean the cylinders are scuffed up. The engine runs perfectly fine/strong without any odd noises or oil burning issues. Thanks for any replies.
Anyone ?
The block I'm building now has two pistons removed so I can see it clearly.
The walls, in the skirt area, have tiny vertical lines where the skirt rides. They look as if they were drawn in with a light pencil. But you cannot feel tham at all, and you shouldnt.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
I know the piston skirts rub off on the cylinder over time and some material may transfer to the cylinder walls, particularly if the pistons are coated with moly or other coatings.
Thanks for checking on that Billman250, I do appreciate the quick reply and helpful information you provide as always. I wish I lived closer to NY, I may just make a trip to NY when it comes time to do my clutch, lol.
Hey Starchland , maybe we can plan a trip to NY next summer
