Photo of what makes your S2000 tick
Old 10-11-2001 | 11:23 PM
  #51
jzr's Avatar
jzr
Originally posted by chroot
Let's see, there are ten of those long rods below the camshafts.... so there must be, uh, 2 1/2 of them per cylinder?
- Warren
They look an awful lot like the head studs to me, with the nuts screwed on. Could be bolts tho - perhaps somebody who's taken theirs apart knows?
Old 10-11-2001 | 11:27 PM
  #52
SteveUCI's Avatar
Are 38 and 39 tensioners for the chains to the left of them?
Old 10-11-2001 | 11:30 PM
  #53
MarkS2K's Avatar
Very cool Ricepimp. Thanks for doing the work of numbering everything. Now we can really get down to identifying everything.
Old 10-12-2001 | 12:38 AM
  #54
RicePimp's Avatar
[QUOTE]Originally posted by jzr
[B]They look an awful lot like the head studs to me, with the nuts screwed on.
Old 10-12-2001 | 04:55 AM
  #55
Windscreen's Avatar
22 - lost motion assembly (believe that's what Honda calls them). These keep the center rocker following the big cam lobe until you get past VTEC. Basically a spring & plunger.
27 - head bolts
28 - cover for cylinder head air injection passage
30 - timing chain tensioner
31 - driven gear from camshaft primary drive (driven by chain from crank sprocket, which is #32)
31, driven gear, then drives the two scissors gears, 40, which are bolted to the cams
33 - oil pump drive chain
34 - primary cam drive chain (timing chain)
35 - oil pump chain tensioner
36 - oil pump chain guide
37 - crank shaft position wheel (for crank encoder in 15, chain cover)
38 - timing chain guide (moveable guide, or slack side guide)
39 - timing chain guide (fixed guide, or tension side guide)
41 & 42 - engine mount brackets?
Old 10-12-2001 | 06:15 AM
  #56
ultimate lurker's Avatar
Looks like #7 was skipped - piston oil squirters
A few items missing from the picture too. No retainers, valve spring keepers, cam cap bolts, etc.
UL
Old 10-12-2001 | 06:53 AM
  #57
dlq04's Avatar
[QUOTE]Originally posted by ultimate lurker
[B]A few items missing from the picture too.
Old 05-03-2006 | 02:18 AM
  #58
Austblue's Avatar
Bumpage
Anyone still have this picture?
Old 05-03-2006 | 11:58 AM
  #59
HOTRODS2000's Avatar
How are you guys viewing the referenced picture? I can't see $hit.
Old 05-03-2006 | 01:10 PM
  #60
S2nOC's Avatar
pics probably been taken down from where it was hosted, threads from 5 years ago
Quick Reply: Photo of what makes your S2000 tick
