Photo of what makes your S2000 tick
Old 10-11-2001 | 08:03 AM
  #31
chroot's Avatar
Hmm this middle column of debris is tough... if someone could tell me what the piece dead center (above the flywheel) is we could get some more momentum here. I'm familiar with everything but that one piece.
By the way, I'm impressed at how few pieces the engine has. Many of the parts are intricate and doubtless a challenge to cast -- but there aren't that many parts.
- Warren
Old 10-11-2001 | 08:09 AM
  #32
dlq04's Avatar
[QUOTE]Originally posted by chroot
[B]Hmm this middle column of debris is tough... if someone could tell me what the piece dead center (above the flywheel) is we could get some more momentum here.
Old 10-11-2001 | 08:51 AM
  #33
chroot's Avatar
dlq04, good call -- it does look like a timing chain cover, after all.
Above the CHAIN CASE, I believe, is the coolant pump.
- Warren
Old 10-11-2001 | 09:34 AM
  #34
Windscreen's Avatar
...guess I'll use this lunch break to finish the center row:
Above the WATER PUMP/THERMOSTAT HOUSING assembly is:
above left - OIL PUMP & PICK UP
above right - OIL COOLER and the OIL FILTER is above that
Next on our way up we encounter the IGNITION COILS (of the PENCIL COIL design type, vs. coil-on-plug)
and finally, above the coils is the WINDAGE TRAY
Old 10-11-2001 | 09:38 AM
  #35
jzr's Avatar
jzr
That's what I thought it was too, but dlq04 thought it was a heat shield...can we reach a consensus?
Old 10-11-2001 | 09:56 AM
  #36
chroot's Avatar
The right column is pretty easy, save a few ones:
On top right is the THROTTLE BODY... there are a lot of parts on that -- anyone care to break it down?
Then below that is the HEAD (every man's favorite part )...
I'm not sure I know the purpose of those gaskets to the right of the head...
The below the HEAD is the VALVE COVER... and to the right is our favorite part... the VTEC SOLENOID...
C'mon everyone, this is fun.
- Warren
Old 10-11-2001 | 10:48 AM
  #37
dlq04's Avatar
It was a test - the official term is BAFFLE PLATE
Old 10-11-2001 | 10:51 AM
  #38
dlq04's Avatar
- Warren
I believe those are CYLINDER HEAD SIDE COVER GASKETS
Old 10-11-2001 | 10:54 AM
  #39
S2KFanatic's Avatar
I know those are valves & springs under the valve cover....but what are those little bits between each of the springs?
Old 10-11-2001 | 11:14 AM
  #40
Pinky's Avatar
Those may be what the valve stems sit inside of.......Though I don't know for sure. Well these next ones are going to get tough.
Next to name is the thing below the VTEC solenoid. Beuwler.......
Quick Reply: Photo of what makes your S2000 tick
