Pending P1399 Mystery
So, I've got a 2000 AP1 with a pending P1399 code. It sets the code ~2 minutes after start-up, simply idling. I can feel the car missing at idle, with a noticeable exhaust burble noise. The car seems to run fine with some load, but misses a bit at idle and occasionally stalls (which may be a dirty IACV).
Full blown CELs were once set for P1399 and P1304 while someone else was driving the car. Although, I haven't been able to replicate the CELs, or see a pending specific cylinder code.
Things I've tried:
- Replaced the plugs with used, but known good ones, no difference
- Moved the #4 coil pack to cylinder #2, no specific cylinder code since
- Swapped in known good coil packs from a properly running '06 CR-V (same as '04-05 S2k's), no difference
- Removed E-manage, no difference
- Verified valve lash adjustment; it's ~0.0005" looser than set when adjusted two months ago (25 degF ambient for adjustment, ~72 degF ambient for check)
- Voltage checked with engine running due to a thread about alternator issues. The dash does change brightness, but the car's voltage measured ~14.1 Vdc with <40 mVac while running
- Checked fuel trims, at cold to warm idle STFT ranges from 5 to 20% while LTFT is 0%; does this indicate a fueling issue?
Work recently performed:
- New intake installed
- E-manage installed
- Header installed
- Valve lash adjustment
- P0410 & P0411 set when first removed from winter storage; these no longer set pending codes and the pump is actually pumping
I'm thinking about the following:
- Having the injectors tested/cleaned
- Cleaning the IACV
- Replacing the MAP sensor
- Separate the header and cat to inspect the catalyst brick (70mm Berk HFC)
What should be my next step? Thanks.
Things I've tried:
- Header installed
- Cleaning the IACV
Check compression?
I'll likely perform compression and leak down tests again.
I performed these last fall, less than 1,000 miles ago. Off the top of my head, all cylinders had 240-245 psig compression and 3-6.5% leak down rates; no real change from the prior year's tests.
I don't want to be that guy but the Misfire Thread has a pretty comprehensive step by step process to diagnosing your misfire.
Anyways, I've solved a P1399 on a customer's car and it came down to faulty injectors. That was on a 2004 w/125k miles. I would try to find someone locally that would lend you some injectors because they are a pretty penny new. As windhund said, compression would be another logical next step as the misfire isn't targeted at just one cylinder.
So, that leaves injectors and compression. I found a local shop to test and clean the injectors, and I'll perform a compression test tonight. At this point I'm guessing I have an injector that leaks or has a very poor spray pattern.
So, compression is fine, now to pull the injectors and perform a leak down for S&G's.
Today (cold):
Cyl 1 225 psig
Cyl 2 229 psig
Cyl 3 221 psig
Cyl 4 223 psig
9/20/13 (hot):
Cyl 1 229 psig
Cyl 2 234 psig
Cyl 3 227 psig
Cyl 4 227 psig
Today (cold):
Cyl 1 225 psig
Cyl 2 229 psig
Cyl 3 221 psig
Cyl 4 223 psig
9/20/13 (hot):
Cyl 1 229 psig
Cyl 2 234 psig
Cyl 3 227 psig
Cyl 4 227 psig
The problem seems resolved with a combination of injector and IACV cleaning. The cylinder #4 injector was slightly down on flow (~4%); so perhaps it had more issues at low flows. Also with the IACV cleaning the idle quality is greatly improved.
From my understanding the P1399 is a pending misfire. Run the car until the ECU figures out which cylinder is misfiring and tags it with P1301, 2, 3, or 4 (for a 4 cylinder car).
-- Chuck
-- Chuck
After the initial codes, I drove the car for three days and it never set another CEL; just the pending P1399. So, I attacked the problem.
