Passenget window wont go up
Well I read through the old topics... But this is different from any other. I installed Rick's 4.57's today and installed the yellow box aswell. I hooked up the power for the yellowbox( to test it) to the passenger window fuse and plugged it back in. I started the car to see if the speedo would work correctly(its does), but as soon as I started the car, the passenger window went down immediatly. It now will not roll down from the driver's side- though it will go up from the driver's side.... It will go up and down from the passenger's side switch
When trying to roll up the window from the driver's side i hear a "click" from the underside of the pass. side of the dashboard...
Fuses are good, and lock switch isn't on either.... any help?
first i'd pull the yellow box out to be certain you didn't improperly cut a wire, and cross a wire somewhere. check those connections. i'm a little confused as to what/why you exactly did, so if i'm on the wrong track here i apologize.
Probably the child safety lock on the driver's door.
This is just a WAG, since I know nothing about the yellow box module - verify that the switch for the power windows is not disabled by the rocker switch on the driver's side armrest.
That's easy to check. Otherwise, I would suspect an error in installation or a faulty yellow box module.
Originally Posted by derek14,Apr 28 2005, 06:11 PM
funny
Anyone with useful info?
Power windows can sometimes reverse polarity in their wiring during the normal functioning of the system. It's always a bad idea to use such circuits to power stuff.
BTW, twohoos was not mocking you. This is a very common mistake that catches a lot of people.
Lock rocker is in the on position... but window will not roll down from drivers side switch...
(I thought Twohoos was being a smart@ss with "child safety lock" thinking that he meant it as a "door lock" not a window lock... apoligies
Anyone with a wiring diagram?
I have a red, yellow and red wire going to those terminals. It's the bottom one you need.
