Passenger Window Won't Go Up
My grandson cycled the top up and down a few times, sometimes stopping part way. The passenger window went down and stayed down.
Now it won't go up with either the switch in the driver's door or the passenger's door. I took off the door panel, and was able to power the window up by applying 12V directly to the two-pin connector. I also disconnected the battery for a couple of hours, thinking a control might reset - nope. The driver's window works normally.
Sorry if this has been solved elsewhere - search is down. Please help if you can. Thanks,
Denis
Denis
Originally Posted by xviper,Jul 8 2004, 08:28 AM
Check the passenger window "LOCK" button on the driver's side door.
Thanks, xviper. I'm always noting your thoughtful suggestions, and this was another one.
