Passenger window problem
Problem:
Passenger window will not go down with the switch, but It will go down when I drop the top, and use the drivers side located, passenger window switch.
Things I have tried to fix it with:
-got a new switch
-made sure the passenger window lock was not on (located on the drivers door)
-checked all the fuses
Any ideas what could be the problem?
thanks,
Matt
-got a new switch
thanks,
Matt
Hey I did thanks,
I should also note, when the lockout switch it engaged both side windows do not work, and when its not engaged i can control both windows from the drivers side
Matt did you get a new passenger switch or drivers side. The drivers side has a control unit built into it.
Find a helms manual under power window you'll find some continuity tests that will track down your problem. You can probably view it online.
fltsfshr
fltsfshr
I replaced the passenger switch, I was not aware the control unit was built into the drivers side switch, I will take a look at that tonight and update tomorrow.
The window will not go up or down using the passenger side switch, If I use the driver side it functions normally
sexysilvers2000
09-04-2018 04:01 PM
