Passenger window problem
This Past week I've been having trouble with the passenger window. It can't roll up or down from both switches from the drivers and passengers side, but when I use the roof switch I was able to roll it down and to roll back use I would have to flip the "passenger window lock" on the drivers side back and fourth. Any idea on what the problem is?
If both driver and passenger switches are dead (no click), it's likely something to do with the window lock switch on the driver's side. I don't quite understand your statement about flipping it back and forth. Maybe it's not making proper contact and needs replacing?
^, yeah, agree, sounds like lockout switch contacts are bad. Replace switch.
having an issue with mine recently too. passenger side rolls down fine, but then it doesnt want to roll up. I do hear a click under the dash on the passenger side. after i try different switches like 20 times it eventually works. scared to roll my passenger window down now.
If all the switches function fine (continuity test)... guess it would have to be the motor on the passenger side?
I have replaced both my window regulators but it would be best to replace switchesfirst sometimes tje passenger switch will get stuck causing it to go down but not back up from the master switch
ap1jay
10-04-2009 10:20 AM
