Passenger window on the fritz
So I ran into the problem of my passenger window not going up there other day. First thing I looked at was my window lock (not the issue). I then took apart my passenger door to test the motor and switch. They both worked as they should. I then took apart my driver's side door to preform the troubleshooting steps. The steps I followed can be seen in the link: https://www.s2ki.com/s2000/topic/947...ow-wont-go-up/. Everything worked great until I tested the blue/red wire. When I jumped the correct terminals I heard the relay working but no window movement (turns out I forgot to plug in the window regulator when testing the passenger side ). Well I then plugged the terminal back into the drivers door and turned the ignition on. Nothing happened until I tried the unlock switch and then the passenger window went down. After that I could not get the passenger window to go back up and operating the switch on either door results in nothing happening. Does anyone have any ideas on what to test next? My thoughts are leading me to a broken wire, or possibly a bad driver's side switch. Any help would be greatly appreciated.
I have tested all the fuses and the grounds. Everything passed there too.
My passenger side has not worked for two years... still trying to figure it out.
I replaced the motor, driverside master switch, tested power, all work.
Somewhere from the switch to the motor there is a loss of power, so i am also worried it might be a broken wire.
sexysilvers2000
09-04-2018 04:01 PM
