Passenger window broke....
Tonight when I was raising the window, I heard a click and the window dropped back down. Now I can't get the window to go back up. It sits there freely. I popped off the door panel to inspect and found a metal cord with a little knob at the end lying around. When I try to operate the switch, there's only a very slight movement from the cord. Would this be related to the window regulator? Is there a diagram that shows the window assembly that I can refer to? I'm guessing that I need to take it in to the dealer service department perhaps. Anyone able to help? Thanks!
Sounds like the regulator came apart. It is usually not fixable without getting a new reg.
On most cars....it will come with the guides, cable routed and intact, you just bolt it in.
