passenger air bag removal
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
First and foremost disconnect neg battery termimal and,pump the brakes a couple times to rid of excess voltage (have radio code ready for after) disconnect yellow comnector, iirc 3 nuts under dash hold it, remove nuts and push up on airbag cover (not bag itself) the cover shuld pop up and out
why are you removing the passenger airbag? If your doing it drop weight, the whole ghetto civic thing.. you do understand if you get into an accident.. not only can the passenger sue the living hell out of you, but you can also be found in neglect if your passenger gets hurt...
shirty
11-17-2010 04:51 AM
