Part number for OEM differential install kit
Just ordered my 4.77 gears from Motorklasse now I'm looking for the part numbers I need to get from Honda to do the install. If anyone has those please post them.
Thanks
Thanks
Are you doing the installation yourself?
Do you know how to set backlash and the pattern?
If you dont know what shims you will need to set this and your aftermarket gears didnt come with them then you can measure and purchase the correct shims, or purchase the shim kit.
You should replace the seals and will need gasket sealer for the pumpkin.
You could inspect your bearings and see if they need replacement.
https://www.s2ki.com/forums/index.ph...c=323308&st=75
A bit down page 4:
91201-PCZ-003 OIL SEAL
91002-PCZ-003 BEARING ASSY.
91001-PCZ-003 BEARING ASSY.
90201-PCZ-003 NUT, LOCK
41271-PCZ-003 PIECE, DISTANCE
A bit down page 4:
mitcho168
03-07-2010 03:03 PM
Redline Drift
Member S2000 Classifieds and For Sale
10-05-2004 08:23 PM
