Part number mystery
Part number mystery
Does anyone know the part number for a replacement 2-pin *connector* on the engine harness that attaches to the intake air temperature IAT sensor? This sensor sticks out of the top of the air intake tube on an AP2.
(Sensor Assembly, Air Temperature) (Matsushita Denshi) 37880-PLC-004.
Not sure where to find the OEM part number for the connector to this sensor. Thanks!
You may have issues finding it as honda likely does not sell just the connector.
You can try findpigtails.com and email them to tell them what you need. They can usually find that sort of thing.
Also, is the housing of the connector broken or did a wire just break off at the pin? If the latter you may be able to re-pin it. That is what I did when a wire broke off right at the pin of the vtec oil switch connector.
Thank you
Thanks for the reply. The plastic lever on the connector snapped off. Awaiting arrival of an aftermarket replacement, but was hoping there might a bag of them available from Honda.
https://www.cycleterminal.com/motorc...onnectors.html
I've found a radiator fan connector here and know people buy coil pack connectors and other things from them. Kinda hard to pinpoint but worth taking a look.
Mr.Matchbox
02-14-2023 11:26 PM
