parking lights not comming on?
Wendsday I turned on my parking lights at night in my driveway and saw that they dont work... The back lights come on but the side markers and the turning signals dont eliminate (sp)... Is this supposed to happen? because I recall someone who took a pic and the lights were on.
Yes... the dash and cluster lights are all on exept the "chan." button and the first top two lights on the AC controll (the thing that tells the air where to flow.)
well the turn signal won't light up and as far as the "chan" button -- could just be burned out.
So here's what i would to first ---> check your fuses. I'm not sure if the parking lights have seperate fuse but it never hurts to check. Then i'd turn wheel all the way in and unclip the plastic from the behind the headlight enough to get to the side marker bulbs and replace them to see if thats your problem.
good luck
good luck
