Parking Lights do not work
Old 08-27-2015, 08:04 AM
  #21
_iRev9k's Avatar
Did anyone ever have any luck whatsoever? This is the only thread I've found in 2 years of owning the car and not driving at might in that long sucks
Old 08-28-2015, 11:56 AM
  #22
toekneer's Avatar
Parking light bulb needs replacement. Do I really have to remove the wheelwell liner? Not having much luck find an answer with search.
Sent by carrier pigeon
Old 10-13-2021, 08:55 PM
  #23
Skeebo's Avatar
Just to document how I fixed this issue after countless Google searches and finally taking off the wheel/fender liner to inspect myself:
I fixed this by unplugging and cleaning the plastic housing that the bulb plugs into (unplug bulb, then unplug the clip that connects to the wires). It looked like melted white/yellow plastic or vaseline-like material was covering all the metal contact points so I just used a flat head screwdriver and q-tips to clean gently this off, then plugged everything back in and parking lights are working perfectly now.
Just to note, my symptoms were that parking lights stopped working (one side at first, then the other side a few months later) altogether (when using remote lock/unlock and when headlights in first on position). Bulbs were good, fuses were good, and no other lights were having any issues. Hopefully this helps someone save some time one day!
Y0N1P8T5R1F5A4T
01-06-2014 11:03 AM
dyhppy
05-21-2010 06:47 PM
xionl1350
07-14-2008 10:42 PM
mugenrsx
07-06-2007 02:22 PM
AP1SiiK
02-16-2007 08:06 AM
Quick Reply: Parking Lights do not work
