Parking light change
My left parking light is burned and in service manual says that I need to remove the hole front light in order to change it.... Is there any quicker and easier way to do it? I've taken a look in DIY section but I don't find something.
Look at your front fender. If you observe it, you will see that just removing a few clips will allow you to partially pry it and have access to your bulbs/connectors. You can fully turn your wheel to the right for more room.
Hope this helps.
I have to remove the wheel to get to it, but its still easier to go through the fender liner than take out the whole light. Remove the two clips on the wheel arch and one more in the liner - you'll see it, and you can just pull back the plastic liner and get to the back of the light assembly.
