Parking Brake Light on
Originally Posted by jtmonkey,May 22 2005, 01:09 PM
....... So, you guys are smarter than the dealer! Thanks again guys.
JT
JT
My first thought was the brake fluid level. I recall once when I did a flush/bleed and the float switch got stuck. Couldn't understand what happened until I saw a similar post. Disconnected the sensor and removed the float and reinstalled. Problem solved.
Use your warranty when possible, but DO NOT take their word for anything. Find out exactly what they do each time. Many times they do half-assed work, reset the ECU and tell you the problem is "solved".
-Hockey
