Parasitic draw?
windhund116 (06-26-2024)
Do you have any aftermarket electrical equipment (like alarms or audio amps) that has its own fuse(s)?
Can you remove the fuse to the unit and recheck the current draw?
The following 2 users liked this post by flanders:
Chuck S (06-27-2024),
windhund116 (06-27-2024)
Yep, as flanders noted you have the meter set up wrong. And there is another fuse box inside the car as thoiboi said. Change the lead setup and verify what you see, then start pulling fuses in the other box to see what you see.
![](https://cimg7.ibsrv.net/gimg/www.s2ki.com-vbulletin/982x1848/image_dc68c159a73d4ad277c00c5ffd33351551731f1f.png)
200mA and below uses the right lead.
Correct. 1.73A >> 200mA, thus he should be using the 10A setup to get an accurate reading and to prevent damaging the meter.
