Paper Clip to obd = Code 71, 72, 74
Hi, I did a lot of searching regarding this issue, but Im not sure which way to go about resolving this issue.
I did the paper clip trick on my CEL, and it gave me 71 72 and 74.
and from what I gathered, they were misfire codeson 1 2 and 4?
What should I be replacing or checking?
I checked the spark plugs, they were fine (quite new too).
Should I somehow get the coil packs tested? How would I go about testing coilpacks? Injectors? or maybe even a leakdown test to see if the valves are seating properly?
Thanks!
Thanks!
Originally Posted by pmptx,Dec 3 2010, 02:00 PM
For coilpacks you just have a known good one and swap it out to see when you achieve no issues.
switch the 3rd to the first and see if it changes to 2 3 4. If it does mark that one good and work your way around cycling the good one in with a suspect bad.
This will help you eliminate the good from the bad and lower the number you have to purchase.
Originally Posted by Billman250,Dec 4 2010, 05:43 AM
with 3cyls misfiring, its not the coilpacks.
You might want to make sure you have good unblended (i.e. no ethanol) high Octane fuel. I have seen various misfire codes set by bad fuel ove the years.
Utah
Utah
91 octane fuels say at the pump "may contain up to 10% ethanol" could this have an adversary effect on the car?
The manual syas under the Oxygenated Fuel Section (2001 Manual) that one can use up to 10% Ethanol or 15% MTBE. I said no ethanol...which is technically incorrect. Not sure what led you to check the codes (i.e. rough running CEL, etc) but I would be suspicious of fuel if you fueled up at a new stop or if the problem appeared on a new tank of gas. As stated I have seen "bad" fuel cause this. In both cases the person had gone to a new station (one was Sam's club and the other was a Sinclair). Both problems with misfire were corrected with new fuel. The owners manual says:
"If you experience any undesireable operating symptoms, try another fuel or switch to another brand of gasoline".
Just a thought as this is an easy fix if thats what it is.......
Utah
Utah
