p1399 and p1259...what's wrong?
Originally Posted by RED MX5,Feb 11 2008, 12:28 PM
Is Mike aware that you're running the stock ECU? Does he think it should work OK with your setup?
Originally Posted by plokivos,Feb 11 2008, 10:15 AM
i bet your knock sensor got tired of trying to stay alive anymore.
Originally Posted by F20Cdriver,Feb 12 2008, 06:00 PM
the first time i got the engine back from mike laskey, i ran the car like a granny, just to break in the engine and it was working perfect on the stock ecu. it had no cels aside from the knock sensor, which was replaced. instead of getting any cel's, the bolts on the timing sprocket snapped off. i took it back to laskey and two valves where bent and replaced at the same time the timing gears where replaced. exact same set up, but now it won't work for expletive. my guess is that the guys who installed my engine did something wrong or my ecu gave up on the set up when it snapped those bolts...who knows? I've opened the valve cover to check if the cam gears where correctly installed and they where. I'm not sure what step to take next. i could buy a new ecu or take it to a honda tech and have them figure it out.
Originally Posted by RED MX5,Feb 12 2008, 03:38 PM
Like everyone else who has commented, I'm a little surprised that the car ran at all (at least without throwing a CEL) with the lowered compression, but obviously it did. Do you have any idea what the A/F looked like? It seems to me that if the car had been excessively rich, or excessively lean, the ECU should have thrown a CEL, and since it didn't, I *guess* it must not have detected anything too far out of spec. Since the car ran OK before, I too suspect that something in the wiring, or elsewhere, got buggered up during the engine install, but it sounds like you are now getting a major misfire due to lack of spark, fuel, or compression. Have you run a compression check yet?
Originally Posted by F20Cdriver,Feb 12 2008, 07:23 PM
no compression check yet. by the way, what exactly is the purpose of a compression check?
If you don't have compression, the cylinder won't fire. Could be the cause of your misfire.
Do both a wet and dry compression check. While you're at it, you might want to do a leak-down test, but I don't think it will tell you much at this point.
If you pull the coil packs one at a time, you might be able to figure out which cylinders are missing (or if it's a random misfire in all cylinders). When you pull the coil pack of a cylinder that is firing, the engine will run worse, but when you pull the coil pack of a cylinder that is not firing, the engine will run the same as before (no better, no worse).
If you are getting spark and compression at all four cylinders, then I'd check for fuel flow. If you have never worked with fuel injection before, you might want to have someone else do this for you, as the high pressure in the fuel lines has to be released to avoid spraying fuel all over the place. If you follow the instructions in the Honda factory shop manual, you'll be fine.
FWIW, this is not a problem I'd want to try to trouble shoot on my own. I'd check for spark and compression, and if I didn't find the problem, I'd probably get our truck out here and take my car down to our shop so our chief mechanic could sort it out. It's not that I couldn't troubleshoot the problem, but just that it's apt to be a time consuming PITA if it's not something obvious. If you're unsure about the purpose of a compression check, you might want to defer all the troubleshooting to someone else.
Originally Posted by RED MX5,Feb 12 2008, 05:08 PM
BTW, you may have trouble finding a Honda dealer that will be willing to work on your modified car.
thanks for the help buddy!
Originally Posted by F20Cdriver,Feb 12 2008, 11:44 PM
yah, i've been turned away from my local dealer already. i'll have to try those tests tomorrow and see what happens.
Good luck!
Originally Posted by RED MX5,Feb 12 2008, 10:59 PM
I don't know how much help any of this will turn out to be, but at least it's a start.
Good luck!
Good luck!
